Question about Cardiozone Exercise & Fitness
I have a cardiozone sports foldaway treadmill the manual does not specify a type of oil to use. I need to oil the belt. Does anyone know if 3 and 1 oil will work?
    Habit-Forming:
    New Friend:
  • 27 Answers
Use a non alcohol based silicon spray or liquid. The WD40 brand make the 3 in 1 silicone spray and it’s good for all non waxed running belts. Just make sure you get the spray in the middle of the belt. (Underneath of course) watch a YouTube video if unsure.
Posted on Jan 03, 2019
  • 80 Answers
You should check with the manufacturer. Some oils will destroy materials used.
Posted on Jan 02, 2019
2 Suggested Answers
6ya staff
SOURCE:
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: need a safety key
buy it from www. fitnessrepairparts.com
God bless you
Posted on Oct 02, 2012
E1 error code
This usually means a faulty LCB or motor.The fact it has not been used much doesn't matter. It is 7 years old. Usually you can not see faulty parts on the LCB. I do think if you really want the answer call a treadmill repairer . If you don't know what you are doing it can be dangerous.
Dec 03, 2013 | Cardiozone Supersport Hr Club Commercial...
CardioZone SuperSportHR Club Fold-Away II ERROR 1
see the video and proceed according. God bless you
2) LUBE the rollers bearings too
3) test the drive belt motor, and replace it
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for help
5) Test the output voltage board, for input voltage motor, if there are NOT THE board is faulty. see the block d.
God bless you
Nov 29, 2012 | Cardiozone Supersport Hr Club Commercial...
I am looking for a owner's manual for CardioZone treadmill Model CZ SG65. I can't find anything on the internet.....can anyone help?
Go to treadmilldoctor.com or call them@ 1-800-750-4766 since Keys Fitness went out of business they bought the parts inventory I am assuming that they will have manual for you unit.
May 07, 2010 | Cardiozone Supersport Hr Club Commercial...
My treadmill come on but the belt dont move
Sounds Like a Motor control Board,they don’t often fail on their own though; usually it’s because you failed to lubricate the belt at the manufacturer scheduled maintenance periods that is specified in your owners manual. Go to iconfitness.com click on customer service then replacement parts put in manufacturer name and model name it will give a listing of parts , availability and pricing.
Apr 16, 2010 | Proform Sport 1000 Folding Treadmill...
My treadmill belt just stopped, message error E
Unplug your unit, then remove motor shroud have a good light the sensor is either mounted on the frame by the front roller/pulley unit or it is mount on the motor sometimes by the flywheel sometimes on the opposite end. Next step is to locate the motor control board and plug you uit in. Your board should ligt up with red ,green, or amber L E Ds now manually move the running belt and you should see one of those lights flicker or not if it does then the sensor is working , then we other issues, if not either we have a defective or misalign sensor. An if your unit needs lubrication use a synthetic silcone product.
Mar 13, 2010 | Cardiozone Exercise & Fitness
How do i lubricant my treadmill
it is an indicator that the belt needs lubricating. turn the power off, and lift up one side of the belt and spray a small amount of lubricant underneath the belt, onto the running board. repeat this step on the other side. turn the treadmill on and run it for a few minutes to spread the lubricant. the oil light should now go off.
this should be repeated every 5-6 months to keep the board lubricated and to reduce friction between the belt and board and will lengthen the life of your treadmill.
Dec 19, 2009 | Reebok New York Giants Eli Manning Jersey
I-run treadmill belt does not run
Maybe check the troubleshooting section of your manual. If you don t have one, check here.
Feb 20, 2009 | Reebok New York Giants Eli Manning Jersey
Oil can caption on my reebok fusion treadmill (rev10301)
It means that you need to spray silicone between the belt and the platform it runs on
Jan 10, 2009 | Reebok New York Giants Eli Manning Jersey
Exercise & Fitness Logo
60 people viewed this question
Top Cardiozone Exercise & Fitness Experts
Jesse Garza
Treadmill Repairs...
Are you a Cardiozone Exercise and Fitnes Expert? Answer questions, earn points and help others
