SOURCE: Simpson esprit 550.The agitator is not moving in
Had the same problem with mine, could be a number of things but in my case it was a relatively simple fix - but you'll need to buy a part.
Open the lid and look inside, the bit sticking up in the middle of the machine is called the agitator. Remove all the fabric softner and lint filter from it and you'll see one very small bolt at the base.
I concocted a number of ratches stuck together to reach it but once undone you can pull the enitre agitator up an remove it.
The agitator is driven by metal bolt with teeth at the bottom of the tub, however the agitator itself is made entirley of plastic, therefore (prob due to age) the metal teeth had eaten away the inside of the agitator and so it was just spinning inside its hole!
eplace the agitator and problem solved.
SOURCE: My simpson eziset 550 washing machine just stopped
Replace the fuse inside the control panel make sure you turn if off.
depending on where you are the fuse is more than likly a "4amp slow blow" fuse
hope this helps
SOURCE: simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Testimonial: "thanks for the tip"
SOURCE: My simpson easyset 550 washing machine keeps
my simpson 550 wint spin, its stuck with a tub full of water and wont drain it. what should i do?
