Miele 1213 touchtronic washer drum appears loose, very loud during spin & clothes still mildly wet at end of cycle- what parts possibly would I need?
SOURCE: Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
SOURCE: GE washer (wjsr4160gww) makes loud noise during spin cycle
Remove the front panel and you will see two metal guides attached to the front of the frame. One of them will probably be bent and the transmission assembly will have jumped over one or the other of the guides. You need to manually pull it back to center then straighten the bent guide. May have been caused by load being out of balance or machine not properly leveled. Good luck.
SOURCE: Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
SOURCE: miele touchtronic 1113 washer
There is a float switch in a pan under the machine. This pan is probably full and the float switch is causing the Intake & Drain fault signal. You can lean the machine over to towards the front to partially drain the pan. Put a towel down to catch the water. When you put the machine level again the fault lights should be out. The real question is where did the water come from. You can easily remove the top (4 screws, 1 on each side behind the little plastic caps and 1 on each side of the back. Torx heads) and look down inside while you start the cycle. Look for leaks.
Good Luck,
Dan
