I am in Arizona what time zone do i set it to?
SOURCE: need operating manual to set time and date
Just posting a solution to remove this from unsolved problems list. thanks and good luck.
SOURCE: I have the timex 1440 wr50m radio control watch.
Good day Sir, This model (WR50M) has four buttons, from left to right, top to bottom:
1) Set; 2) Start/Stop; 3) Mode; and 4) Indiglo.
To set or change the time:
1.Press and hold Set and Start/Stop simultaneously; the seconds will start
to blink
2.Release both buttons
Use Mode button to toggle through to Hours, Minutes, etc.
3.When desired number (such as Hours/Minutes) starts to blink, use
Start/Stop button to change number
4.When done, hit Set
have a nice day.
SOURCE: Radio controlled clock model 6302000 - cannot
I have the same clock and had the same problem. My clock was a demo and had no instructions with it. Here is the solution:
1. Pull out the battery and wait 10 seconds then replace the battery. The satellite symbol should start flashing after a few seconds.
2. Put the clock outside or in a window sill till it updates. This could take a couple of minutes.
3. Press the Mode button once to enter programming mode.
4. Press the Adjust button as many times as needed to toggle through the time zones.
5. Press the Mode button once to exit programming mode.
