SOURCE: How do I set 24hr
here's the procedure and visual image for easy explanation.
Image 1. SET TIME (ANALOG)
1. PULL the crown all the way out. TURN the crown in either direction to adjust the time.
2. PUSH the crown all the way back in when finished.
Image 2. MODES (DIGITAL)
1. PRESS the EL button to activate the light.
2. PRESS MODE button to switch between Time Mode and Alarm Mode. Time mode is recognizable by the flashing colon. In the time mode the current time or dual time is shown.
By setting this display to another timezone it can be used as dual time.
NOTE: This is not recommended if you plan to use the alarm. The alarm relates only to the time on the digital display, not the analog display.
3. PRESS EL button to turn alarm on and off in alarm mode. In alarm mode, the alarm time is shown
Image 3. SET TIME (DIGITAL)
IN TIME MODE
1. PRESS and HOLD MODE button to set time
2. PRESS EL button to advance time.
3. PRESS MODE to change between hours and minutes until you reach the correct time.
PRESS and HOLD MODE to exit time setting.
Image 4. SET ALARM (DIGITAL)
IN TIME MODE
1. PRESS MODE button to switch to alarm mode PRESS and HOLD MODE button to set alarm.
3. PRESS MODE to change between hours and minutes until you reach the desired alarm time.
PRESS and HOLD MODE to exit alarm set
Just let me know if I can help you further..
SOURCE: Just bought a nixon synapse watch. Got it on the mail today and it isn't even turning on. Help.
this is new one or use.
