The tv comes on and shows the logo and turns rite off.
SOURCE: SMART KIT DRUM CARTRIDGE
Call 1-800-821-2797. Thats a machine software issue..
Here is the note on it.
Problem:
The DRUM and TONER cartridges are not installed correctly. Web page indicates replace %0 empty cartridges. The Machine doesn't copy.
Cause:
Firmware and work-process problem.
Solution:
Fixed! Did not fix.
Don t worry about cartridges. They are safe. Upgrade firmware.
The message goes away and machine copies
SOURCE: Westinghouse tv ltv46w1hd sound no picture
www.cfusion.com has the spare parts for that tv. it sounds like it is the mainboard. shouldn't be more than 150-200 to replace.
SOURCE: westinghouse model tx-47f430s lcd tv wil not turn on
This is known as SLEEP MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These step is done to over-ride the sleep mode.
Roan
SOURCE: Westinghouse SK 32H540S when i Turn on TV, get
The problem is cause by the transformer on LIPS inverter (Power supply + Inverter board). You could see an obvious burn on the 1 of these transformers ( There are total 3 black transformer on this board). The part number is 4302H. It is available online at http://www.lcdparts.net/TransformerDetail3D.aspx?ProductID=2775
SOURCE: Westinghouse 32 lcd tv - no picture no sound - set
Reset the tv and the cable or satalite boxes,replug it back an hour later let the tv reset it self back to factory setting and the boxes upgrade it software.The tv should work now.Not,than yes.It the Tuner main board.
Testimonial: "Quick response got me in the right area."
