Question about Kyocera Office Equipment & Supplies
How to repair kyocera mita km 2050 with error C0610
    Champion:
    New Friend:
  • Kyocera Expert
  • 250 Answers
Replace main PCB
Posted on Mar 20, 2019
6ya staff
SOURCE:
Anonymous
  • 126 Answers
SOURCE: KYOCERA MITA KM-1500 ERROR CODE C7980
C-7980 - Means that the waste tonerresevoir in the process unit is full with less than 100,000 copies onthe unit.
Clean/ empty the waster toner and vac.Also clean the sensor.
You may have to change the Process unit if cleaning does not work.
Posted on Mar 02, 2009
Anonymous
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Posted on Mar 12, 2009
Everett Lin
  • 990 Answers
SOURCE: kyocera mita error codes of KM 1500
Hello sir; The error code you display A3200 is not available in our menual, we do have C3200 , if that's correct, it means exposure lamp burn out ( not on), replace it, or thermos fuse out.
Posted on May 13, 2009
Anonymous
  • 157 Answers
SOURCE: kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
Posted on Sep 18, 2009
mysticus_tam
Tammie Duggan
  • 57 Answers
SOURCE: Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
Posted on Dec 21, 2009
Error c0610
KOUSERA COPIER KM-2050 CALL SARVIES C0610
Nov 29, 2013 | Kyocera Mita KM-2050 Printer
Kyocera km 2550 error c0610
Replace the main PWB and check for correct
operation.
Oct 26, 2012 | Kyocera Mita KM-2550 All-In-One Laser...
KM-2050 Printer: i need to find the pin number to my kyocera km-205...
I need to create a new pin on kyocera 5050 machine as the old one is lost
May 05, 2010 | Kyocera Mita KM-2050 Printer
Printing problems Kyocera KM 2050
when this error comes up..hit the print button on the left hand side..this will than tell you on the screen wha the actual problem is..i.e ( out of paper...lost connection etc
Jan 29, 2010 | Kyocera Mita KM-2050 Printer
Kyocera km-2050 scanning function
Mar 04, 2009 | Kyocera Mita KM-2050 Printer
Driver
From links below you can download driver and manual:
KM-2050 driver KM-2050 utility KM-2050 datasheet KM-2050 installation manual KM-2050 user manual
KM-2050 documentation
Do not forget to rate the solution.
Thanks
Feb 23, 2009 | Kyocera Mita KM-2050 Printer
Open Questions:
44 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
