Question about Wurlitzer Music
I have a Wurlitzer omni 7000 keyboard computer organ with no sound How I can Reset it or can I
    Sergeant:
  • 272 Answers
6ya staff
SOURCE:
Fred Yearian
  • 5603 Answers
SOURCE: I have a Casio WK3500 keyboard. How can I reproduce the
Try voice 9 in the bank 96. That is for a theater organ type sound. You would need decent sound system to amplify this and to sound anywhere near decent.
Posted on Aug 27, 2009
Fred Yearian
  • 5603 Answers
SOURCE: highest 13 keys on top and on bottom boards do not function
Those notes are likely scanned along with all the others. The strobe selection lines for those are likely failed... this might be only two wires.
IF you have ribbon style cables in the unit, this is often caused when people pull the cables by the edges to remove from connectors.
Look for this and a connector that might have one end lifted where a couple wires aren't quite connecting. THIS IS not ANY ISSUE OF FUSES.
Posted on Jan 13, 2010
Fred Yearian
  • 5603 Answers
SOURCE: No sound from my Wurlitzer Model 1407.
Try ORGANFORUM.com for answers on this.
Posted on Mar 23, 2010
ABRsvcs
  • 4234 Answers
SOURCE: wurlitzer organ model 4060 will turn on but only
Haven't had the pleasure of working on one of these in a while!!
The problem is most likely dried up capacitors in the power supply. Any audio shop should be able to work on this. They may require you to remove the power supply though. There are folks that repair these in-home as well. It may take a little research, but check with local music shops for someone to repair this. The parts cost will likely be in the $40 range.
Dan
Posted on Aug 15, 2010
Michial Gueffroy
  • 1140 Answers
SOURCE: I have a Wurlitzer Funmaker organ that has no
Contact Morelock's Organ Service, Rienzi, MS, United States Phone 601-462-7611. Provide them with the complete model number and expect to pay for a service manual if they have one. Start at the end of the power cord and work towards the amplifier section. You will want to establish that the power supply is working correctly. The light is only an indication that the power cord is getting power to the power switch. If the power supply is providing the correct voltages to the other circuit sections of the organ then you will have to trouble shoot each one separately. Check to make sure the speaker is functional. If it has a headphone jack test it also as it may cut the sound to the speaker out if headphones are plugged in. If it is faulty, sound may not get to the headphones or the speaker. You will also need tools. At least a volt/ohm meter.Remember not to work on the circuits with the power on unless you absolutely know how to do this safely. There are lethal voltages in the power supply.
Posted on Dec 19, 2010
Wurlitzer C200 organ, volume pedal does not work, the Great keyboard is at full volume. Can't find anything online. Can you help me find information on repairing/replacing the volume pedal?
full volume ??? hum that's funny , as if pedal has broken one would suspect that it would go to lowest volume and stay there , 1st id ck to make sure the "bright" switch is not on or stuck on then id dive into taking the cover off the pedal assembly , for a look around to see if somethings obviously not right in there (hanging springs, swinging levers, etc)
Oct 13, 2016 | The Music
The top keyboard of my Wurlitzer 630 does not come on. The other 2 keyboards work fine. Could I have blown a fuse and how do I check?
It's doubtful it's a fuse. More likely there is some corrosion buildup on a ribbon connector. if you're not familiar with electronic organ repair, it would be best to get a repairman to come check it. There's too much risk of bumping the wrong thing inside and ending up in a worse spot that you're in now.
Jan 25, 2015 | Music
Have a wurlitzer model 4300 d no sound, appears to start , not tried to fix purchased in the 60"s
NOT FOR BEGINNERS
These old organs need careful handling - try any visible fuses. Probably cheaper to replace with a modern keyboard which can do far more - sad to say! Sorry
Feb 14, 2011 | Music
Mar 21, 2010 | Music
Highest 13 keys on top and on bottom boards do not function
Jan 13, 2010 | Music
Seeking all wire out, power and impedance info for Wurlly 4100
Try this link and contact Morelock's organ parts for a service manual:http://mitatechs.org/node/612 Please rate this if it helps.
Oct 29, 2009 | Music
I have a Casio WK3500 keyboard. How can I reproduce the sound of a Wurlitzer organ?
Aug 14, 2009 | Music
Wurlitzer organ, highest key plays note one octave too low.
If this is the kind of organ with the wire sticking out of the key that makes contact with the bus bar to create the note you will have to make sure that key is operating the same as adjacent keys. The busbars have to be clean and the contact wires have to be clean. Sometimes when cleaning the wires they will spring out of place and not make contact with the appropriate bus bars. Check that key against the rest and see what you find. Hope this helps.
May 17, 2009 | Music
Music Logo
59 people viewed this question
Top Wurlitzer Music Experts
rostit
Marvin
Marvin
Vernon Taylor
Are you a Wurlitzer Music Expert? Answer questions, earn points and help others
