Dryers Logo
Toni Estes Posted on Dec 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the lint filter on Maytag bravos xl - Maytag Dryers
Chris Huff
Level 3:
Top Expert:
  • Maytag Master 6,289 Answers
  • Posted on Dec 09, 2018
Chris Huff
Maytag Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2017811
Points
74913
If it’s a dryer, it’s in the door.
May tag manual on bravoxl
Possible free manual - model needed - use Comment menu choice to add information to your question.
https://www.manualslib.com/manual/702804/Maytag-Bravos-Xl.html
Maytag BRAVOS XL Use And Care Manual
Oct 31, 2018 • Watches
Why maytag washer is leaving white streaks on my dark clothes
It's lint that hasn't lifted off of the garment. Fluff it in the dryer to remove and find in lint filter when done.
Why maytag bravos keeps blowing thermal-fuse
Lots of videos here about that problem.
maytag dryer thermal fuse replacement YouTube
Which thermal fuse. The one on the heater or the one on the lint filter housing? If it was the one on the heater did you replace the thermostat too.
Is the dryer vent blocked, has too many elbows, or too long or otherwise restricted, or is the dryer overloaded.
https://www.youtube.com/results?search_query=maytag+dryer+thermal+fuse+replacement
Maytag Bravos 300 tub stuck down
if this is a washer you should not have to remove the tub unless re placing seals and bearings!
My Maytag Bravos XL electric dryer doesn't dry clothes. When I try to run a second cycle it seems like it's too hot and won't start again until it cools.
Make sure your vent pipe is clean and filter is clean. Air flow is number one reason for dryer failure, Check the whole inside of the dryer for lint build up and in the exhaust pipe. The dryer has to vent the humid air in order to dry the clothing. If it can't do that, it overheats and also the humidity stays inside the dryer.
Maytag Bravos XL MCT will not start, light is stuck on "detecting" under airflow. All vents and lint trap are clear.
If the vent output is clear and lint trap is clear, then there are a couple of more hidden spots that air can get backed up.
First off, unplug the dryer before doing any of this. There's a lot of current to that plug, and getting killed is a really bad way to detect a bad wire or to identify where the heater coil inlet is.
  1. Inlet to the heater area. Laundry rooms have lint in them. All the air that gets blown out the back has to come from somewhere. make sure you don't have a clump o dust bunnies on another section of the rear panel.
  2. The blower motor itself. The lint filter can't get everything. The first time I took the back off my old Kenmore and opened up that area after the lint trap, it was like looking at a chalkboard eraser. Solid lint. The fins in the blower were packed tight with more lint. Cleaned it all out, and it ran better than it had in years.
  3. If the wall/floor connector for the vent hose goes anywhere but straight through the wall to outside, look down the hose and clear what you can, then go outside to the outlet and make sure it's not blocked, jammed, frozen shut, or what have you. Clean what you can from that end too.
    Hope this helps!
Good Luck!
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
