Industrial
SOURCE: Singer 132K6 industrial machine
Make sure that the thread is under the tension spring then thread it throgh the hole in the spoolcase,push the spoolcase retainer over to hold it in then turn the balance wheel towards you to pick up the thread through the hole in the needle plate, pull both threads back and sew away. I can supply a manual for this machine if you want one.
Robert
SOURCE: How to adjust belt tension
When you say 'Vintage'-- how old are we talking about?
Please describe the belt...
Is this an old Pedal (or platform that you rock your feet, to make the drive pulley go around)
Is it a 'pedal' powered machine?-- one with a round leather belt?
If it is the latter--
Is that belt all dried out?-- or is it still supple and still providing a good surface to grip the grooves of the 2 pulleys?
Tell us more-- maybe we can help.
Mack B
SOURCE: I have a Singer Industrial
Well you may please follow the link below to get your manual -
http://parts.singerco.com/IPpartCharts/16-188.pdf
Good Luck!!
Thanks for using FixYa!!
Testimonial: "Thank you so much for your help. I have looked online everywhere I could think of and found nothing. Thanks again."
SOURCE: instruction manual for singer double needle sewing machine
Judy. AN647555 is the serial number of your machine. I'll need a picture to help you identify. Manuals are not found typically in the regular area at singerco.com
Picture please and I'll direct you to the right area.
