Your photos all have a date stamp as well as all the camera settings when shot and are revealed in your editing software. I don't know how to have the date printed on the face of the photo. You can download the 226 page manual at http://panasonic.ca/viewing/ALL/DMC-FZ70P/OI/vqt5b76/vqt5b76.pdf
Enjoy your camera
SOURCE: Canon SD 1000 time and date stamp on downloaded photo
Set the resolution to PostageCard (1600x1200).
Many of these cameras have only ONE RESOLUTION setting which allows you to have a date/ date and time stamp on the file, which will print on the viewed or printed photo.
How to do it:
Turn the camera on M mode.
Use the func. set.
go down the menu to the resolution settings. (on the bottom of menu).
Pick only the postagecard (1600x1200) setting.
I also was like you, and had an awful time with a camera I was fixing. I then looked it up on the Net and found an online user manual for the Canon SD 500, which should be basically the same.
SOURCE: How to date/time stamp photos?
No. with digital cameras there is no need to do so, as the date and all other details, such as what lens was used and exposure, etc. is stored in the image file as EXIF data. If you need a date-stamp for legal purposes, I suggest you submit the original image, preferably RAW, from the camera.
SOURCE: Remove date/time stamp from photos
go to menu at shooting position. scrooll down to date menu and follow the succeding instructions.
SOURCE: Show/print date stamp on my photos
In order to imprint the date stamp on photos, the photo size (L, M1, M2, M3, S, Postcard) must be set to Postcard, and in the recording menu the "Date Stamp" option must be set to Date or Date & Time.
Testimonial: "Perfect! Thank you so much..."
SOURCE: Remove Date Stamp
You can easily remove it with photo editing software such as Photoshop Elements. If the date is in a corner, you can also crop the picture so the date is left out.
Testimonial: "Thank you for responding to my predicament with the date stamp. It's been a valuable lesson learned to leave the date stamp turned off. BTB"
