SOURCE: sir i have toshiba e studio 163 my machine
u have installed a toner that is not original ,,,try to put an original toner ,,,and then try or let this toner get empty and then try the original one,,,,
SOURCE: toshiba e-studio 720 toner low message but bottle
If everything is OK, but the message is still appear, then u can clear it by following below steps:
User Function--> User--> General--> Toner Near Empty Detection -->Yes
SOURCE: toshiba e studio 170f error message, toner not
maybe the roner cartridge you inserted is not supported by Toshiba e-Studio 170f. This may be one of the reasons that the machine can't recognize the toner cartridge.
Reinstall the toner cartridge that you have. If that doesn't fix the issue try to replace the toner cartridge with new one.
If you continue experiencing this issue contact your technical support team.
SOURCE: e-studio-232 adding toner problem
change the developer with the new one and change the sensor toner.
SOURCE: Toshiba E-studio 212 How do diserbleToner recognition sensor
Oddly enough, I just had the same problem with "OEM" toner. The chip on the toner bottle was not working correctly. I installed another toner & the bottle was detected. The bottles that did not work I throw out. You may want to try to return the bottles that are not working correctly.... Good Luck
