Refrigerators Logo
Posted on Aug 04, 2009
Flashing lights on hotpoint fridge
We have a FF187e future frost free hotpoint firdge. Lights have been flashing all day and it initially it was also making a bleeping sound. The sound stopped however after the freezer door was opened and shut but the lights are still flashing. Can anyone help please.
Edna Wallace
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 23, 2009
Edna Wallace
Contributor
Level 1:
Answers
Questions
Helped
1838
Points
I have a hotpoint future FF187E both lights are flashing how can i stop them flashing ?
The fridge part is not working freezer fine. N the display setting lights keep flashing. It's a hotpoint future fridge freezer
I don't know about all the flashing lights. but if your refrigerator isn't working, but the freezer is, It is usually your cooling fan is not working
What setting should the hotpoint frost free ff187e be on ?
forget "settings"get a thermostat and run the freezer at -18c and the fridge at +5 these are the ideal temps for storage and economy.
1helpful
Light on top of fridge keep flashing
Hi I found the hotpoint site, from there i found the manual for my fridge freezer.
4helpful
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 • Freezers
11helpful
Hotpoint frost free ff200e flashing lights and beeper freezer food defrosting
Make sure fridge OFF freezer OFF ... then turn mains on. ONLY turn freezer to max, after 30mins put fridge to 1care ... this should overcome the problem of the flashing lights. When both nice and cool turn settings down. it worked for me
8helpful
Type hotpoint ff187e fridge section not cooling lights flashing
It is ice build up in the ducts in the fridge/Freezer section. If you switch off and let it defrost with doors open for 24hrs all will be OK. I have just paid £100 for a call out just to be told this solution to the problem which is something that should be in the inst. manual or told when reporting this fault to try first. One big con from Hotpiont.
Fridge freezer not working after power cut
if its a ge i would say itsyour main board not compressor boards about 200
9helpful
2answers
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 • Freezers
Hotpoint FFL49X Fridge compartment
GE Hotpoint has a history of bad fans and poor customer service. Unfortunate and a costly defect. Repair this yearly, forever or trash and buy new???
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
