Maybe the reason is that the excitation voltage is too low, so it can not reach 220V. You can try to adjust excitation voltage.
If you need to have new diesel generator set, please contact [email protected]
the governor is not set properly, good job catching this issue. also check it under a load, if you still find the voltages too high, I recommend having it serviced.
setting the governor can be tricky.make sure you mark the shaft.
