Model #GU2475XTVY1
SOURCE: Model 665 16874
removed and disassembled inlet water valve - minature basket filter was clogged with white particulate which felt gritty. cleaned and reassembled and reinstalled. Works fine now. Idiot repairman never mentioned a filter but wanted to replace entire valve at cost of 140 dollars including service call. sears sux bigtime. And, from my experience with Fixya, so does your service since I never heard a thing since July EXCEPT for an offer to upgrade. Thanks for nothing.
SOURCE: whirlpool dishwasher top Spinner and top rack
First, confirm that the holes are not blocked on these arms. (I did not want to assume you have done this.)
Then check the impeller on top of the motor stem for being loose or worn/damaged - to rule the impeller out. If it is fine, then the motor is failing and too weak to drive the spray arms.
To answer your question, I think the answer is "They don't make them like they used too!"
SOURCE: My Whirlpool quiet partner dishwasher seems to run
try a large cresent wrenck,or channel lock plier.ps.might place towel over plastic nut,to protect from wrench damage.
SOURCE: Whirlpool Gold Dishwasher - GU2700XTSB The
I
have an older dishwasher also and recently my wife also complained
about it not cleaning right... so me being the man I am tried in vain
to clean the things... Bought new spray arms online and installed
them in minutes...now the thing works like new... However I have also
found that if the heating element goes bad then that also can mess
things up bad... So I would buy new spray arms, and also check out
the heating element to make sure it is working... Here is a tip that
will help you with the online buying...
Dishwasher
Residue and Film on Dishes
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
bad heating element causes many problems in
dishwashers...
Dishwasher Problems The Heating
Element not Working
Dishwasher
Maintenance
heatman101
I
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
dishwashers...
Element not Working
Dishwasher
Maintenance
Dishwasher
heatman101
