Green lines/shadow appears on the characters and objects on my LG tv screen when I turn it on. It usually go away within 20- 30 minutes. I troubleshoot by replacing the hdmi cable and change the cable box. It also appears while using the apps. What could be causing this problem.
Something is changing inside the TV. Most likely a voltage from the power supply since that would affect the different circuits that are causing multiple visual symptoms on the screen, and as the voltage returns to normal; all of the symptoms go away. Suspect the main power supply board in the TV, Most likely there are faulty filter capacitors that control supply voltages by filtering out AC interference.. When they start to go bad they begin to run warm and it takes them longer and longer to start working correctly. Probably (probably) when you first noticed the problem, it went away in a few minutes and it is taking longer and longer for it to clear up.. Sounds like they are close to quitting completely !
SOURCE: Hitachi 53UWX10B Projection TV colors not lining up...
STK392-110 sub to upgrade STK394-160E Part # CZ 01341
SOURCE: printing color shadow
did you used a combat able cartridge ? if yes the ink is the problem if no the problem is firmware
SOURCE: 3 horizontal lines across screen and triple shadow on left side
its a LCD connectors. re-connect it properly. some loose connection.
SOURCE: Green shadows appear on new visio SV470VT. Very
It maybe a circuit control board for the screen. Last thing you want to do is void the warranty by opening up the TV.
Best to use the warranty at this point. Here's info to get you started.
Phone Numbers
Technical Support or To Place an Order
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
[email protected]
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
SOURCE: LG HD 37 INCH TV GREEN LINE APPEARING ALONG THE BOTTOM
On a LX2R to remove the green bar at the bottom or the blue bars on ths side using the sky HD box go to menu and the pip menu at the bottom of the list, access input and make sure the HDMI input is on DTV and NOT PC.
