1, You can very well scan using the HP Deskjet 2652 printer. Since it does not contain the Scan option from its control panel, you can follow the procedure below to scan.
2, Mount the document or image that you want to scan, on the scanner glass.
3, Press the Windows Start button and look for HP; choose your printer name.
4, Now, the HP Printer Assistant tool opens; click on Scan a Document or Photo to launch HP Scan.
5, Choose a shortcut and then change the following settings.
6, Scan Preview and the Destination folder to save the scanned file.
7, Click Advanced Settings to align the above settings and then click OK. Redo these steps for every scan shortcut that you create.
SOURCE: how to scan from Hp printer to a Macbook
I've not used this machine, but it should be a simple procedure by following the installation procedure for MAC OSx....drivers are here:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=219&lc=en&dlc=en&cc=us&product=1128296&lang=en
SOURCE: My HP F4280 Deskjet All-In-One does not scan!
Under Control Panel, click System, than click hardware, than click device manager.
Uninstall USB Controllers, and than unplug the USB cord from back of the PC.
Once the USB controllers have been uninstalled, restart your PC.
Once the PC has been restarted, put the USB Cable back into the PC, and let the Operating system reinstall the drivers.
This should reinstall all drivers such as twain, usb, etc..
Sincerely,
Ryan Deschaine
Systems Engineer
Boxen Solutions LLC
http://www.boxensolutions.com
Email address: [email protected]
Office number: 262.432.3120
Mobile number: 262.364.6196
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
SOURCE: HP deskjet f2280 won't scan
you can try clicking MY COMPUTER then C: then PROGRAM FILES then Hp then Destination folder then bin then find the hpscnapp with a printer icon.Scan will work.Hp 2280 frequently encounters error especially if you're using VISTA. Hope i helped! Good day!
SOURCE: hp deskjet f2280 need help scanning
this is a two step process first you scan the image and save it, usually you can find it under my scanned images folder, desktop, my documents, or use the search functionality to find your scanned file. For mor information about scan settings visit:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01567026&lc=en&dlc=en&cc=us&product=3390947&lang=en
you can then just open your word, go to Insert, picture, from file and browse to previously saved scan file.
Hope this answers your question.
SOURCE: hp deskjet f2200 will not scan picture... prints
You have to update the driver.Click on the following link,
F2200 is superceded, so select 2210 or 2200
Select the full feature software.
This includes the scanner utility as well.Install th eprogram.
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=f2200&submit=Go+%C2%BB
After installing if you register with HP, you will get automatic updates.
Good luck
luciana44
