SOURCE: Tecnics SU-G95 stereo overloaded
Power down,disconnect the speakers and power back up. If it still say's overload, it needs to go to service. If not, check your wires, connections, and speakers one by one to hunt down the problem and correct. Hope this helps
SOURCE: I have a Technics Stereo Integrated Amplifier
Are these resistors near or linked to whatever is on the heat sink? If they are then they are bais resistors and they have burned up due to a fault on the devices on the heat sink.
Resistors are cheap, all you need to do is find out what value they are. This is part of the colour code. However if they are burned then you might not be able to read the code! So you will need the circuit diagram or someone to tell you the value.
The problem however will be if whatever on the heatsink has gone!
It could be an IC since you have lost both channels, unless you have shorted the speaker wires of both channels somehow and blown both right and left amps!
SOURCE: My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
SOURCE: I have a Technics stereo integrated amplifier SU
It chirped because the bearings were worn out, then it froze up and isn't moving any air. Get it replaced. DO NOT run the unit if it keeps overloading or you will have a bigger problem.
SOURCE: Technics SU-g75 Amplifier. No longer
ALL speaker jacks must be loaded and closed for any sound to come out of this system. Missing one speaker, or one bad connection and you will get no sound or some will work and some will not. speaker wires need to go deep into speaker jack holes.
