I have a kenmore 90 series top load washer theat goes through the entire cycle but at spin it doesnt spin. It does make a noise like it should be spinning but when I open the lid to take a peak the drum isnt moving. Please help! Ive checked the coupler and the transmission was replaced but still no spin.
If your trans and coupler are good then I would suspect the drive block or spin tube. You will have to remove the trans to change out the spin tube. Take out the basket, there should be 2 ears from the spin tube that nest in the drive block. Attached is a photo to help you understand. Before all this make sure nothing is caught between the basket and the tub. Catriver
I am having a similar problem with the Kenmore 90 series. Sometimes my washer does spin out, other times not. If I help it by pushing the tub around sometimes I can get it going. (I have to defeat the lib switch to do this.)
How do you get the tub out ? or the basket ?
