How long to repair ?
SOURCE: Nissan Maxima car repair ripoff
I'm wondering if your injectors are leaking. If they are, and the car sits for a period of time like you're saying, fuel would puddle up and the car would run extremely rich until the excess puddled fuel burned off. Did you (or do you) notice black smoke from the tailpipe during the time the car is running really rough? Take a look and see - rev the engine if you need to, and see if you see some. It'd take a few minutes to burn off, and once it did, as long as the rest of the car is working right, you'd run normally. If you shut the car off for a short time (ie, getting gas, renting a movie) the car likely wouldn't sit long enough for enough fuel to puddle up for the condition to recur. If you park it overnight, that's plenty of time for the injectors to leak enough fuel for the car to run rough on startup.
No guarantee of course, but that's what sounds like a worthwhile investigation to me.
SOURCE: whirlpool washer machine shakes badly when cycle
The problem could an improper leveling of the machine.Also could be bad drum bearings or even damaged ones because of the previous heavy spins.
SOURCE: I have a kenmore washer 700 series. Water is
Yes its true that this washer not worth repair.... Better you can go for a new washer..
I have a question - is there any error code on the display control?
thanks
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
SOURCE: Frigidaire Gallery Series GLTF2940 front load
check the belt make sure it is still contected.
if that is good you may have a faulty door lock
Hello friend, I appreciate your post!
I see you are asking about a Frigidaire washer leaking but your question is labeled under refrigerators. If your washer is leaking it could be a problem within your motor, water valve, drain pump, or seal inside your washer. If you are speaking about a refrigerator it could be an issue within your water valve, water filter, or an air leak causing condensation.
I would recommend having a professional come out to the home for a proper diagnose and repair. I hope this is helpful. -Matt
