Televison & Video Logo
L
Louise T Hartmann Posted on Dec 20, 2018
Proscan 1960A have pic no sound
Check input or source
My dish remote will not turn on my proscan tv so a bought a rca universal remote and it turns the tv on but messed up everything else , so now I can’t get any channel s or pictures at all
Check the Source or Input button. You have accessed a source that has no input signal.
No one buys Universal remotes these days, you buy a facsimile remote that is an exact copy of the old one.
Proscan TV Remote Controls - Replacement Remotes
www.replacementremotes.com > Proscan > Remote-Con...
ReplacementRemotes.com offers Proscan remote controls for sale online including remote controls for TV, TV/DVD Combo, Sound Bar System and many more.
proscan tv remote - Amazon.com
www.amazon.com > proscan-tv-remote > k=proscan+tv...
Results 1 - 16 of 195 - GE Universal Remote Control for Samsung, Vizio, LG, Sony, Sharp, Roku, Apple TV, RCA, Panasonic, Smart TVs, Streaming Players, Blu-ray, ...
Proscan TV Replacement Remote
www.remotes.com > proscan-remote-controls-s
Replace new & discontinued remote controls for Proscan devices with fully programmed remotes from our online store. Enjoy low prices and fast shipping.
Proscan Remote Controls - Walmart.com
www.walmart.com > ... > TV & Video > TV Accessories
Products 1 - 40 of 43 - Shop for Proscan Remote Controls in TV Accessories at Walmart and
My remote that goes to my proscan stopped working and I need to use the side panel to get back to tv mode but I don't know how to select the mode.
Please press source button, you will get the list of input sources.Select the source of your liking ie is TV by pressing CH up and CH dn keys. Once you have selected the source press source key again to get the normal screen.
How to set up pled 1960a-e flat screen tv
hook up ant scan you should be ready to go any problems go to www.proscanvideo.com
My 32 proscan tv has picture but no sound
First be sure your speakers have not been turned off( this is in your menu selections) then try another source such as a DVD player (this to rule out the source, also try a different input to be sure it is not the input. If still no audio most likely is the Main pcb, but possibly lack of power source from power pcb.
How do you connect a peavey 6505+ amp to a marshall 1960a cabinet?
On the back of your 6505 there are two jacks that are labeled speaker outputs. For mono function, use either one of those outputs and run a SPEAKER cable from your amp to one of the input jacks of your 1960a cabinet. I assume it is a 4X12 cabinet. Either input will work. Make sure you match the ohm selector on your 6505 (right next to the output jack, 4/8/or 16 ohms) to the ohm rating on your 1960 cabinet. It is likely labeled on the plate that houses the input jacks. You should be good to go. NOTE: Never turn your amp on unless it is hooked up to a speaker cabinet and never use instrument cable to hook your amp to your speaker cabinet. Bad for a nice tube amp like yours.
Rock on and hope it helps.
I have sound but no picture
Check your source input toggle the source or video **** on the remote and make sure your on the correct virtual input. Also check your cables on both end to ensure they are not loose. lastly i would also try other inputs for instance if your running hdmi try a composite cable it may be just one input affected.
I cannot get my Proscan 40" lcd HDTV out of
Check the resolution on your signal source. Well, first before doing that make sure the Proscan is on the right input i.e. make sure it is on the hdmi input if you have it and you signal source connected with an hdmi cable and then make sure the resolution on the signal source is 1080i fixed. Then there should be a button on the signal source remote (# hdzoom or format or aspect). You should be able to change the picture size with the #hdzoom, format , or aspect button.
How to hook up a dvd on a proscan ps32600 tv
This tv has 2 AV inputs at rear to connect dvd player or any other video source.
Plug RCA video cable in AV Input-1 at rear of tv and select Input-1 source in tv remote to get dvd player playback picture in tv.
Click HERE to download user manual free copy that has details about tv operations.
Hope these info will help you.
Thanks.
Tv screen is white; sound is ok
Need more information about you problem. Does the white screen appear on all functions.Does any input signal like a dvd or vcr show picture. If so, then you have a problem with signal connection coming from the television signal source, like a cable or satellite box. You need to check the connecting cables to see if they are outputting signal. Try using different cables to connect the signal source to the television. If this does not work. Try hooking up the signal source to another television to make sure you are receiving signal from them.If all this seems to be working fine and you are sure that you are using the remote control inputs correctly, you may have a problem the video input signal board on the television. You can contact PROSCAN at this web address. www.oncorpus.com. Go to customer support and ask for their technical assistance with your problem. The telephone number for PROSCAN service is 1-888-977-6722. I hope this has been of help with your problem.
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
