SOURCE: Will not start; makes no noise
check the humidity sensor this will prevent the motor from starting
SOURCE: WON'T COME ON AT ALL.
you have not said anuthing about ohming out the start knob,and have you checked both legs on the power cord are getting 120 volts each?let me know what you find-mike
SOURCE: 1984 toyota camry no brake lights switch fuse and bulbs are good
check wiring further back in boot rh side there is little black box that plays up fitted there.check this cant get anymore must by pass box now.
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
