SOURCE: Maytag Neptune W/D (Stacked) Drying Irregularly
I have a Maytag MUG2000AWW stack drier that heats intermittently. I opened mine up tonight and found that the connector to the gas valve doesn't seem to be making contact. It's on tight, but I can push on that connector while the gas ignition heater's hot and the valve clicks on. I'm off to the store for some terminals tomorrow to improvise a replacement.
SOURCE: Problem with upper cabinent of Maytag Drying Center.
Mine did same thing within warranty. There is a motherboard problem in them that is cause by power surge during an eletrical storm. First try unplugging for 10 minutes and see if it resets. If that doesn't work, you need to have the motherboard replaced that runs the unit.
Repair man took the front off my unit and replaced entire motherboard. He stated that it was a known issue with that motherboard. I have had no problems since my motherboard was replaced 18 months ago.
SOURCE: Maytag Nepyune not drying completely
There is a cheap PDF repair manual on eBay for this model. It is item number
200258764242.
Premmy
SOURCE: 99 minutes
It sounds like you may need a new timer. Has water or anything gotten into the timer. This could be causing a short or faulty reading in it.
First try cleaning the moisture sensors with rubbing alcohol,
these are two silver colored strips located inside the drier just below the
lint cleanout
