I ran the program through a reset hoping it would correct the problem, no it did not. I have the PR 09 setting the same as all the other dryers. But, it still is showing er 22.
SOURCE: display saying f-10
Heater or thermostat faulty, probably thermostat, there are 2 of them, replace both.
SOURCE: dryer will not heat up Does run
It's probably the thermostats that are normally attatched to the element or it could be the element itself. They are nprmally placed in the rear of the appliance.
The thermostats will only cost a few pounds.
SOURCE: Speed Queen gas dryer model #AGM499W. Replaced the
burner may need to be vacuum out or blown out, also could be the thermo coupler. Hope this helps tim
SOURCE: I have a speed queen electric dryer model number
There is no reset button, check yoru breaker, by turning FULLY OFF (somewhat forcefully off) then back on and test again.
All thermal limiters will auto reset when cooled...
SOURCE: Brand new Lg dryer 2501, error code ''nP''
I had the same issue with two new dryers. The rep on the phone said nP can also indicate a power issue. It turned out one of the wires in the outlet had broken off. Rewiring the outlet solved the problem.
