Any manual will be at SONY, this mobo is a contract made.
Asus, to sony, and made to SONY SPEC.
one poster said
from my SONY vaio pcv-rs346. (and is)
no service manuals sorry or gee ask SONY.
what you do is plug in the front panel connector.
it is keyed
but you lost the front panel assembly didn't you.?
why play P4 relics, 99% are in the landfill.
it is possible that asus used there standard(internal) wiring
here and only changed like 3 times in 20 years.
2003 made PC, it is, a true fossil.
or ask the bad boy that sold it to you.
did you also lose the sony VAIO PC casing?
sorry i can't see it to know know what's UP DOC.
here it is sold just like this, rs346
the panel has 6 , cables and are not documented
they simply plug in. (lost this did you? ) use the word lost or?
this is the real part, had to search very old sales transactions.
but there it is in all its relic glory. worth exactly zero.$
Hi
find link
front panel wiring diagram for asus p4sd-vx
https://www.google.com/search?q=front+panel+wiring+diagram+for+asus+p4sd-vx&sa=X&hl=en-US&biw=1366&bih=657&tbm=isch&source=iu&ictx=1&fir=0Rh1hvVyGnNKnM%252C5uIMIopNyomrBM%252C_%253B12LCAuLm_-YJYM%252CIbNzLUjch0OcAM%252C_%253BUuAquVX0QstuZM%252CxQvksBLcSfN7lM%252C_%253BJxNBDUI8AcQk5M%252C_AjCjcugs5ZHsM%252C_%253Bo72QEp15nYgyXM%252Clyf1sjBbo9TwGM%252C_%253BfCFEdzFkIzUrBM%252CunBOH_dNTh5MPM%252C_%253BlT57XNMQoz-fTM%252CunBOH_dNTh5MPM%252C_%253BkGCTVB121H_LPM%252Clyf1sjBbo9TwGM%252C_%253BkDcv2JVBwnzp0M%252CloQ2ZiB0YOzheM%252C_%253BXSf8yFbXnVxrZM%252CeKhQzXydABtV4M%252C_&vet=1&usg=AI4_-kQywYveAIgyr0GHx3rlo2kKycEkag&ved=2ahUKEwjU062M9an0AhW49nMBHclvAX8Q9QF6BAgOEAE#imgrc=UuAquVX0QstuZM
RTM at asus.com
https://www.asus.com/us/support/
Hi Hilal yasin, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
page 15 start reading, non sony non VX P4
https://www.manualslib.com/manual/444695...
asus ended p4 support.
2001 is first year of p4 there.
and has ended.
P5 up yes, lower NO.
seen in some Sony Vaio, PCs
VAIO PCV-RS430G (2003)
the VX code i think means just that sold only by SONY,. not ever from ASUS direct.
under contract VAIO to Asus. custom features, see?
and sony support is sux.grade.
look
https://www.ebay.com/itm/124485932766?ep...
the truth is here,
see it's a SONY
lost this too.
the whole case and all cables lost?
bingo, fossil day.
next.
SOURCE: need manual for p51p asus motherboard
You can find the manual for your motherboard from this web site:
http://support.asus.com/download/download.aspx?SLanguage=en-us
SOURCE: how to wire front panal
You will need to open the computer case and check that the cables that run from the actual power button to the motherboard are plugged into the proper spot on the motherboard. Sometimes reseating the cable can fix this issue.
I think this is the link to your motherboard documentation: http://www.via.com.tw/download/mainboards/3/4/p4mapro533_r100.pdf
Check the page 2-14 or 2-15 and see if that helps you to identify the actual connection for your power switch.
