Televison & Video Logo
Kenny Jackson Posted on Dec 22, 2018
Hitachi ultravision digital 65s500 it has a converter place on the back do I put the coax there or do I have to have a converter box
5 Related Answers
jason
  • 905 Answers
  • Posted on Dec 03, 2008
SOURCE: Old VCR with NTSC tuner
is the coax cable tv? if yes then no you will not
if it is just an antenna , then yes you will need the converter box
Anonymous
  • 5138 Answers
  • Posted on Dec 27, 2008
SOURCE: Need help locating a box to make my TV receive true HDTV
You Dont need one your set is HD. So when the switch happens you are good to go. The only TVs that are going to need converter boxes is those who do not have HD or only have antenna.
Anonymous
  • Posted on Jan 01, 2009
Your Hitachi 43FDX01B is HD-Ready, which means it has high definition capability, but it needs an HDTV Tuner added to it. DTV converters can only give you Standard Definition resolution. You can browse HDTV Tuners Now for the different types of HDTV Tuner that are available.
Anonymous
  • 2992 Answers
  • Posted on Jun 06, 2009
SOURCE: is my Hitachi 61uwx10b ultravision hd ready
This TV will need a converter box. It was made in the days before the digital tuner was required on big TV sets.
Just remember the converter is only needed if you get off-the-air reception with an antenna for local channels. If you have cable or satellite and get your local channels that way, you don't have to do anything. The change to digital will not affect you.
If you are now using rabbit ears or an old worn-out outside antenna, you might think about upgrading your antenna when you get a converter box. Signal strength is very important with the new digital broadcasting. Too weak a signal means no picture at all or one that freezes up or turns blocky. The antenna that worked for analog may not be adequate for digital.
Anonymous
  • 197 Answers
  • Posted on Jun 07, 2009
SOURCE: Lamp box is open or assembled wrong on my Hitachi Ultravision DLP 2005 model
it is in the front pop the front cover off, look in the owners manual
Hitachi 65s500 dim
try this
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=Hitachi+65s500+lamp&rh=i%3Aaps%2Ck%3AHitachi+65s500+lamp
I have an ultravision hdtv, model #65s500 64
You can Google the model number----I just did and found possible free download for owner manual:
retrevo.com/support/Hitachi-65S500-TVs-manual/id/.../t/2
REGARDS, SD TECH
1helpful
Is my Hitachi 61uwx10b ultravision hd ready digital tv ready when they switch over to digital vrodacasting or will i need a converter box,
PS2 won't work with magnavox dtv converter box
first off make sure u have the box turn off
this is what i would do:
i would get a short coaxile cable and splitter and hook them up to your tv
........................TV.........................Coax input
.........................|..............................Coax Wire
......................../\.......................................Coax Splitter
....................../...\.......................................Coax wire from ps2 and dtv box
...............PS2......DTV box......................
Hope this helps
Digital to analog converter box hookup
You will have to go to Radio Shack or Wall Mart, maybe Home Depot and get a matching transformer. That will have spade terminals on one end to connect to your tv and a round (75ohm male thread) to hook to your converter box.
Hitachi Ultravision rolling horazontal lines
Mine has the same thing when I have a Component AV S-Video Switch (one that can have muit- rca connections along with coax TV line on it ) the component switch caused interference and caused that line
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
