SOURCE: Sync Outlook Contacts & iPhone
You need to creat "Folders" in outlook and move all contacts to the different folders. These "Folders" are then recognized as "Groups" in iTune and you can sync Contacts by Groups.
iTune does not recognize Outlook's "Categories", or even Outlook's "Groups"; iTune only recognizes "Folders" as groups.
Problem solved.
SOURCE: How to sync contacts from iphone to outlook 2003?
When you connect your iPhone to the PC that you always sync with, Go to Info tab, Check the box Sync Contacts with: and select Outlook. Then make sure that you check the box Put new contacts created on this phone into the group: and select a subfolder in your main contacts folder.
This way, all the contacts from your iPhone will be saved into another folder in your main contacts folder of your Outlook PST.
Let me know if you have any questions.
Thanks
Sandeep
SOURCE: my iphone 3G does not starting up it simply shows the apple logo
U PLS do as i say ..............Open iTunes and connect the iPhone to your Mac or PC
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
The iPhone screen will remain black like this:
NOTE***: It may take a few attempts to get your iPhone into DFU mode. Generally, I hold down both buttons then release the Home button just before I think the Apple logo would appear. If you are still holding both buttons down and you see the Apple logo you are holding them down for too long!
SOURCE: my apple iphone USB Device Not Recognize what will
Go to www.itunes.com and download and install itunes, then reconnect the phone. If you already have itunes do this, but realize this will clear the info from your iphone, but if you have the info in itunes, it will sync back anyway. So just know, this does a factory reset:
Turn iphone off by holding power button on top left and sliding the red bar to shutdown.
Now, take the usb cable and have it not connected to the computer, but connect it to your iphone, so now you have the usb cable just connected to the iphone which is completely off.
Now, hold down the circle button on the iphone, and keep it held down. Then insert the usb cable into the computer, while still holding the button down. After a minute or two, you will get a screen on the iphone with a white usb wire pictured on the screen, and if you did it right, the connection should then pop up on windows. After you do the restore, you can then use itunes and plug in the usb like normal, all should be fine.
good luck!
