First if the error code is "EE" then unplugging unit from power<waiting a few minutes and then plugging it back in might reset control board.
Second, are you sure it is "EE" and not "tE" or "fE"?
good luck
Make sure the washer is level, especially front to back. Do not overload washer. Check to see if marks are coming from build up of gunk in the outer bowl.
• The connector in the LEAD WIRE ASSEMBLY is not connected to
the connnector of STATOR ASSEMBLY
Reconnect or repair the connector
• The hall sensor is out of order/defective.
Replace the STATOR ASSEMBLY
Steve R is right except that if the splines in the rotor are stripped you will have to buy a new rotor or the bolt will just continue to lossen itself up. The rotor is $64.33 online. Still a ten minute fix, after you wait a week for part delivery.
you need to clean the two water pumps on this model i had one and was totaly baffled to why it was still not pumping and still blocked till i found it had a two pumps good luck the pumps are under the machine just follow the outlet pipe
