SOURCE: im loose my wires
Here you go:
This is the wiring diagram for most all the kenwood radios for the last few years. Yours included.
If you need more help just ask.
A good rating would be appreciated.
SOURCE: kenwood kdc-x491 wiring diagram
red, yellow, black/ign constant ground
blue, blue white stripe/rem pwr ant
grays, whites, purples, greens/ front front rear rear
its the same on all headunits except cheap *** wal mart headunits
SOURCE: need wiring diagram
red is power,yellow is constant 12v for memory.blue is power antenna,purple and purple with stripe is rear right speaker,green and green with stripe is rear left speaker.white and white with black stripe is front left,and gray and gray with black stripe is right front speaker. the power antenna can be used as a remote source to turn on the power amplifier.
SOURCE: need to know what the wiring diagram for kdc-x789
well if you mean how to wire it up to ur car buy a radio adapter from best buy and color match all wires
Red wire ignition ...yellow wire connstant battery ...blackwire....ground...blue and white remote out....solid blue ..antenna...all white n black is negative and all solid color is positive for ..speaker connections..orange or orange/white is dimmer or illumitation
