Replaced hall sensor
SOURCE: at spin cycle pump only runs for 3 seconds then stops
Sounds like the pump motor is overheating. Probably need a new one.
SOURCE: Hall Sensor Fisher & Paykel mw051
Discount Parts
Major Appliance
& Consumer Electronic Parts.
TOLL FREE 1-(888)-338-3790
8:00AM - 12:00 MIDNIGHT
7- DAYS A WEEK
Here is a good parts discounter we use. If in stock they ship quick .
Please give me a good rating before you sign off fixya.com
SOURCE: On our Fisher and Paykel, the spin cycle does not
what modle do you have how old is it does it power down and turn off or does it stop and start beeping at you have you tried it with no clothes in it and if so does it do it then , these machines are very simple as they have vert few machancal parts post a phone number and i will call you
SOURCE: F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
SOURCE: water is not pumping out of my fisher and paykel
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Please revert for any further assistance.
Hope this helps...
Daniel
