First is it belt driven? If so than that is most likely your issue. Replace the belt. If that is not the problem than check for an issue with the drive.
If it's a turntable with a usb connector, those connections are usually outputs only. USB on a turntable is used to output the audio to a computer to rip albums to digital audio.
Most turntables are belt driven. Suggest you take a look inside but remember to unplug the deck first. Usually it's a simple case of slipping the belt back on.
If it is a turnatable that starts spining when the arm is moved to the record, then more than likely the start/stop switch inside the turnable is broken and is fixed in the on position. Or the leaver mechanism has become detached from the arm when the record was playing and left the other part pressing on the same switch that turns the motor on or off. Removing the bottom of the turntable should should show the trouble.
The self-lubricating bushing in the turn-table is dried out. This is a difficult problem to solve and best left to an expert. Don't expect great results.
