SOURCE: Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
SOURCE: severe vibration on spin
tilt the machine back and check that the blue clips that secure the suspension legs to the base are in place and both the legs are secured top and bottom.
SOURCE: Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
SOURCE: Loud noise on spin cycle
most common cause for this is pump bearing on water pump. remove belt and attempt to turn pump by hand. if it grinds get a new pump.
SOURCE: indesit WIB111 vibrates excessively on a spin
It sounds as if one or more of the drum supports, which are springs or shock absorbers, have become detached or are in some way damaged. You would need to take the back and top off the machine to check this. Otherwise you will have to call a service engineer.
Alternatively, if this is a brand new machine, the reason is that the transportation fixings have not been removed. These are typically two or more steel rods that hold the drum in place, and have to be removed when the machine is installed, and before it is used, If they are not removed there is no damping of vibration as the drum is not free to move on its flexible supports.
Testimonial: "Thanks that was really helpful"
