Right side screen darker started suddenly last week
Try clicking the auto adjust button on the screen. If this doesn't work it may be in demo mode, so click the fENGINEbutton on the monitor and make sure it is selected on the normal setting.
Dude you are genius :) worked for me :) thanks a lottttttttttttttttttttt
Ha d to laugh when I googled the problem and it came up with the make and model of my monitor. I'll second that comment - dude you're a genius. Many thanks :)
Thanks... My screen is "healed"! :-)
thanks a lot, had this very issue and was a bit worried when i saw some other posts on back lit bulbs being burned out but this was the solution so cheers
LCD panels are backlit, usually with 2 bulbs, one on each side. For some reason, the bulb on the right is not lighting. It's either burned out or power is not getting to it.
You might be able to disassemble it and follow the electricity, probably less than 30V DC. Check what the left side is getting and look for it on the right. Just need a cheap mulitmeter and a screwdriver.
