SOURCE: epson styllus pro 7800 service call error 0001002d.. help
http://www.largeformatrepairs.co.uk/technical/maintenance-error-code-0001002d.htm
This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage.
Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions
Please rate the answer........
Just like any other mechanical equipment, a printer requires attention to keep it running smoothly. So, just like when the check engine light illuminates on your cars dashboard so does your printer, but instead of a spanner the error 0001002D will appear on your control panel LCD which is informing you that a maintenance procedure is due to be performed. This will normally involve replacing the parts which keep the print head clean, hence the error "cleaning unit END OF LIFE" and the waste pads. This procedure can be undertaken here at Large Format Repairs for the Epson Stylus Pro 3800 right upto the beast that is the Stylus Pro 11880.
Worn flushing box
Worn cap assembly
Worn head wiper
Worn carriage waste pad
this error 0001002D means Cleaning Unit end of life
The only fix for this problem is you have to call Epson and state them
that you are facing this problem. They will provide you the codes to
unlock this error. Its a universal solution that only Epson can provide
you these unlock codes and you cant find in any websites.So contact them
and get your problem fixed soon.
techbelkin
