Kitchen Appliances - Others Logo
J
James Strandlof Posted on Dec 29, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I remove bread pan from my new oster bread maker?
Inky Fingers
Level 3:
  • Master 705 Answers
  • Posted on Dec 30, 2018
Inky Fingers
Master
Level 3:
Answers
705
Questions
0
Helped
433482
Points
1443
Most bread makers are similar and require the paddle to be lifted off to allow removal of the bowl.
5 Related Answers
Anonymous
  • 944 Answers
  • Posted on Jul 01, 2007
SOURCE: Bread maker bread pan
These are the guys you need to contact; http://www.sears.com/sr/misc/sears/custserv/custserv_index.jsp?BV_SessionID=@@@@0801139933.1183283071@@@@&BV_EngineID=ccigaddlflgehgjcefecemldffidfmm.0&vertical=SEARS Hope this helps :)
Anonymous
  • Posted on Nov 13, 2008
SOURCE: Need replacement bread pan for West Bend 41042 bread maker
TRY ABTECPARTS.COM
Anonymous
  • Posted on Dec 10, 2008
SOURCE: Zojirushi bread maker, BBCC-15, Baking Pan,Paddle drive seal
Where can I get replacement parts for the BBCC-15? My keeper clip underneath the baking pan came off and is lost. It holds the wing clip that drives the kneeding blade in the pan.
Anonymous
  • 204 Answers
  • Posted on Jan 11, 2009
SOURCE: removable bread pan is leaking oil
http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Anonymous
  • Posted on Apr 15, 2009
SOURCE: Bread pan pops out during kneading, hard to remove after baking
I have Breadman Ultimate for over 12 years now. I make bread 2-3 times a week for the past 10 years. I found that the bread pan popping out only happens when the motor shaft and the kneading paddle are not tightly engaged. I find this problem in the following two scenarios: 1. The bread pan was not pushed down all the way as described by cassie_hobbs and tlcquiltnut. 2. Debris filled up the motor-shaft bowl underneath the bread pan to prevent a tight engagement of the motor shaft and the kneading paddle. These debris are generated during the kneading process; part of the ingredients is pushed out of the shallow horizontal pan and accumulated underneath. To avoid the problem, I have to periodically remove debris from the shaft bowl and make sure the pan pushed all the way down. To reduce the debris, I made a simple cover for the bread pan by cutting an old aluminum baking dish. I always remove the cover after the kneading cycle to prevent the rising dough from reaching the bottom of the cover. Hope this helps. Wendy
I think I need a new pan for the Oster 5838 Bread Maker. Any ideas where to buy?
You need part number 102529-000-000, listed as backordered. Suggest contacting Oster at 1-800-334-0759, they may know when or where it is available.
I have a oster 5814 and set it to cook over night and found water on the floor. it leak from the bottom. Can it be fixed or should i buy a new one? My wife loves this model
The sealed bearing in the bottom of the bread pan is broken and leaking. You don't need a new machine, but you will need a new bread pan. Hank
3helpful
2answers
Oster 5821 Bread Maker: Paddle froze up, does not move
That shaft fits into a sealed bearing that is riveted to the bottom of the pan. When that seal freezes there is no way to free it up. The lubrication in the sealed bearing gets hard, especially if it's not used much..You may try putting hot water in the pan and soaking it but other than that the pan will need replacement. Sorry...Hank
2helpful
Paddle sticking in bread when baked bread is removed. Oster Breadmaker 5838
This is a common problem. The solution is to take the paddle out of the machine after the last kneading cycle and before final rise/bake. You may want to take the pan out of the machine to remove the paddle to be safe...unless your machine has a pause cycle. Hank
1helpful
Oster 5834 bread pan failure. Spindle that turns the paddle fell
There is no kit to fix it. Check out ebay or Amazon for a new bread pan. When my bread pan broke it was too expensive to replace, so I just bought a new Sunbeam at Walmart for under $50.00. Hank
3helpful
2answers
The driver that operates the kneading blade ( paddle) is falling out of the baking pan from the bottom. It appears a washer has disintegrated. Pieces seemed to fall apart when cleaning. any suggestions? I...
There is a sealed bearing at the bottom of the pan. This allows the paddle to rotate. The bearing has failed and is falling apart. This usually happens with age or use. Time for a new bread pan. If you are lucky you can find one on ebay. Sorry for the bad news....Hank
1helpful
Need to replace bread pan
I think eBay has one. Chek iyours with th picture.
Hank
http://cgi.ebay.com/OSTER-Bread-Maker-Machine-DOUGH-BIN-PAN-5858_W0QQitemZ330343821138QQcmdZViewItem
I need to fix the rool of the pan Oster 5838 Bread machine
http://minneapolis.craigslist.org/hsh/574471930.html
Try this link, ther is a bread maker for sale used exellent shape.
Also try www.oster.com and contact customer service.
Top Oster Kitchen Appliances - Others Experts
John
John
Sean Wright
Sean Wright
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
