Using the QSC GX3-300 amp
SOURCE: Pin connections on Spkr out jack
did you every get an answer for this i could use it now [email protected]
SOURCE: Connecting a subwoofer to a mono amp that has 2 sets of terminals
ok this gets confusing sometimes. Ok first look to see what ohm your subs are. If you have a dual 4 ohm sub When you run that on sub + to + and - to - then that will make that sub 2 ohm. its different on ohm if the sub is say a 8 ohm then putting the wires that way will bring that sub to 4 ohm. Now lets say you have 2 subs that are dual 4 ohm and wire both of them + to + and - to - and go bridge the amp which would be both wires from sub both + together and both - wired bridge on the amp will make it a 1 ohm to the amp. Please post what ohm your subs are and i can tell you alittle more about it
SOURCE: Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
SOURCE: KAC-9104D output terminals
ok i have the same amp and 1 2ohm dvc sub and was woundering the same thing but from futher research and askin sum xsperts. What i found out is that it is only one channel and even tho there are 2 (+) and 2(-) they actually connect inside the amp makein it one . so if u wanted to wire sumthing parralel u wouldnt have to hook wires from one coil to the other on the speaker , u can just hook it up to the amp. so basically both +'s and negatives on the amp are actually one within it so all the power if you only use one set of them and if u wanna add more subs its just easier to add to the amp by using the xtras .
SOURCE: how to wire for 3 ch mode
this is the manual and you will find all you need in it.
http://www.fixya.com/support/p78783-eclipse_ea3422_car_audio_amplifier/manual-18248#
