Help, Maytag MAH 4000 AWW Thanks for your professional help. I am a plumber. My door IS locked and Locked Light is ON, but my washer will not spin. When I turn the inside tub, there is no resistence. I took off the top panel and there is no sign of burnt elctrical anything. Took off the rear access and found the belt and pulley in good order. Pulled the electric motor and it spins freely. Motor will not run during operation for agitation or spin. I already replaced the wax switch on this fine machine about two years ago. It has been such a sad investment. Please help, Thanks Kevin 4000AWW - Washer runs all cycles fine and agitates well, and then drains as designed. I observed this all with rear panel off as I replaced the drain pump. When the machine gets to the spin cycle, it will not spin, but appears to be doing a version of the agitation cycle, and sounds like it is continuing to drain, but nothing is draining. When completed, the test load was soaking wet and not ready for the dryer, so spin will not work, but everything else appears to be in working order.
SOURCE: Washer wont spin. BUT, DOOR IS LOCKED. MAH 4000
Solution is right ...its your MCU Easy repair.
~Baloo
