Question about Electrolux Washing Machines
I have an Electrolux model T5550 dryer coming error machine stop 10:15 what does this mean?
    New Friend:
  • 12 Answers
The emergency button has been pressed. Remove the emergency by pulling it out
Posted on Nov 09, 2019
6ya staff
SOURCE:
Colin Stevens
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
FitzOriginal
Chris Hall
  • 842 Answers
SOURCE: Zanussi Electrolux ZWF 1430 W (E20 error)
I'm fairly sure that this is a warning that the filter is blocked. There is a filter in the bottom right hand corner of the machine.
Now, as stated by the other user here, your problem is that you have a machine full of water and if you remove the filter, you are going to get a very wet floor. The trick here is:
Turn the power off at the mains and remove the plug from the wall. Wait ten minutes. This SHOULD power off the safety feature that allows you to open the front load door.
Presuming it does, pull the machine out if it is under a work surface and taking great care because of the weight, tip tha machine backwards until the water level is below the door (Having a chair or a box to rest the back of the machine on is a good plan here, so you don't tip it beyond about 45% and have it fall on ots back.
If the door will open, then you can now rescue any clothes and bale out the water with a cup. Once you gave got to all the water you can (Memember there is still more waqter out of sight and in the pipe going to the filter!) You can now tip the machine back a little further until the water is clear of the filter in the botton right of the machine.
NOW, you can take the filter out, remove the fliff, couns, old sock and other debris clogging it and screw it back in place. TIp the machine back on to its feet and put it back.
Now, make a note in your diary to check the filter ever 6-8 weeks or so. Once you have done a few check and cleans, you will figure out how oftem you need to clean the filter, which depends on what you wash and how much you wash it.
Posted on Feb 15, 2009
protek480
Craig Butler
  • 1730 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 25, 2009
Danny
  • 160 Answers
SOURCE: e 20 error code on electrolux inspire washing
e20 usually means not draining...check for blocked filter, or obstructed/ faulty pump unit...
Posted on Dec 21, 2009
Ku Jon
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Posted on Nov 20, 2011
Electrolux 7kg sensor dryer stopped starting to spin unless you started it by hand now nothing works at all.
what do you mean start it by hand,do you mean if you spin the drum by hand helping it to spin it starts if so you have a bad motor.also next time send the full model number off of the dryer.
Nov 30, 2017 | Electrolux Dryers
Dryer Electrolux EDP2074GDW stopped functioning. The question mark is on. Pressing the buttons don't operate the machine. How do I reactivate the dryer?
Condenser dryer? check the tank water level and drain - condenser doors are closing correctly and fluff filter is clear. Question mark doesn't mean fault always - you need to check something. Error codes usually begin with F something.
Oct 15, 2017 | Electrolux Washing Machines
What e54 error code mean on an electrolux dryer
You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
E54 - means the motor is inoperational.
Could be:
  • Excessive wash load.
  • Voltage too low.
  • Motor/transmission system inoperative.
Dado
Aug 09, 2014 | Electrolux Dryers
E64 error code electrolux dryer
E64 - Heater thermostat
  • Thermostat faulty (replace heater unit)
  • Heater unit faulty
  • Wiring faulty
  • Electronic board faulty.
Dado
We have an electrolux Wascator T3530 . It is showing a fault F1 on the display. What does this mean?
First thing you can try is to unplug the dryer for fifteen minutes or so. If that still bring up the error code then it is your board inside your dryer.
May 03, 2011 | Electrolux Dryers
Sep 25, 2009 | Electrolux EIED55H Dryer
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
Washing Machines Logo
425 people viewed this question
Top Electrolux Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Poppa Maddo
Poppa Maddo
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
