SOURCE: philippe starck ph-1071
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps,
SOURCE: philippe starck with fossil ph-2006
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
SOURCE: Can't set the time or adjust the ******** crystal Starck PH-1100
Take a VERY close look at yor watch and you should notice a few tiny buttons. One of them should correspond to MODE, another to SET and so on- depends on how many your watch has.
Use a pin or a needle to push them and find out the settings procedure.
If you cant find buttons on the case sides, examine case back. They can be hidden between the lugs, so, the strap should be taken off.
Remember- there are no watches in existance without adjustment features. Even atomic clock needs to be adjusted after a few million years of work:))
Good luck.
Arthur
SOURCE: how to change the greeting
press the mode button twice. that will change to date mode. during the date mode display ,hold set for 5 seconds. mission accomplished!
SOURCE: what battery does a Fossil Starck PH-1006 watch
Hi. I´ve got a ph-1030 and it works with a `RENATA 350`. I couldn`t d this reference so I bought a similar one.I got the `SR1130W` . This battery works but you have to place an small tape on the back (negative pole), to insolate the battery. You have to do it because this battery is a litle bite smaller than the renata 350. If you need anything else email to [email protected]
