I guess you got the alarm AL 6 on your display what means failure to drain. A control procedure has been added to all the final drain phases in order to check the status of the pressure switch. The contact must be open in the "empty" position in order to ensure that the cycle is performed correctly. If the contact is closed, the drain phase is repeated. At the end of the second drain phase, if the pressure switch contact remains closed, "AL" alarm condition is generated.
Could be following:
Down under is from AEG Favorit 86460 user manual, page 30 :
...a flashing fault code appears
an audible signal informs you that an alarm has been activated, in the display appears one of the following flashing alarms: AL1 - AL2 - AL3 - AL4 - AL5 - AL6 - AL7, AL8 and the indicator light of the phase under way is flashing. They are indicative of a fault in the dishwasher that you can probably rectify yourself.
- press the On/Off push button to switch the dishwasher off
- open the door and carry out the following suggested corrective actions.
Dado
SOURCE: AEG Favorit 40650 dishwasher is
Remove the controller from the top of the door. Extract the main PCB from the plastic case. You will probably see a burn mark on the inside of the case adjacent to the relay on the back of the PCB. Examine the back of the PCB for burn marks around the relay pins. Resolder the relay and any damaged track.
SOURCE: The drain pump on the AEG oko favorit 6050 keeps
Empty all the water from the salt resevoir, (I used a turkey baster), then rock the machine backwards and forwards a few times and empty the last few drops from the resevoir again.
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
SOURCE: aeg dischwaher model oko favorite
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
SOURCE: drain pump keeps running AEG oko favorit
