Hello Adrian,
Most likely your machine error has to do with the water pressure
switch. Here is a couple of links that may be helpful to you.
Good luck,
JP
https://www.manualslib.com/products/Lg-Wf-T652-3265355.html
https://www.google.com/search?q=lg+wf-t652&client=firefox-b-1-d&tbm=isch&source=iu&ictx=1&fir=jju_lgnIhS28SM%253A%252Cnku_8EiLlSD9EM%252C_&vet=1&usg=AI4_-kS1DyN2ARf9FWwNvkTTEehFQV0icA&sa=X&ved=2ahUKEwjo89_Dxf3iAhXrw1kKHVO1BZgQ9QEwD3oECAAQDg#imgrc=jju_lgnIhS28SM:
SOURCE: LG WF-764STP
Washer capacity- 7.2kg · 8 Washing Programmes · Child Lock · 53 cm Wide x 54 cm Deep x 85 cm High
SOURCE: Machine wash but wont rince or spin
It doesn't spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
SOURCE: My machine did not spin out the water, maybe there
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
SOURCE: LG washer Model wf-t6517te not draining water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
SOURCE: Hi, we have a LG
working on lg for a while we have talked to tech suport and they don't want to admit they have a issue with these units.. first of all they say if on a pedastal they will give you problems but yet they sale the darn things... what we have found though is there is a device called a haul densor and it is very easy to replace you have to remove the backof unit panel and gain access to the back of tub... make sure it is connected well as it is on a rotor looking device called a stator assembly... if it is connected well and you have made sure it is level you have a bad haul sensor...thsi is what determines the speed of drum and slows down unit if getting out of balanced.. it is not that expensicve and pretty easy to fix.... hope this helps you out...
servicer 18 years
