SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
SOURCE: defrost timer location
need to know the make and model...
GE are in the top right back
Frigidaire are under the toe plate left and right also in the back by the compressor. cheaper frigdaire are in the middle center top refer... so you see they hide them in a lot of places..
SOURCE: amana ref mod.drb2201cw I need to
you left the chat but if you want to see a view of it go to www.apdepot.com enter the make and your model number and you can see the timer there
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
SOURCE: Defrost timer went bad. How do I manually bypass the timer?
IF ITS A DEFROST TIMER AND NOT A BORD THE WIRES ARE HEATER POWER COMPRESSOR THEN NEUTRAL IS ALONE.
I I I I
HPC N
GOOD LUCK!
ERIC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Testimonial: "I connected a jumper from the compressor to the power and I'm back in business. I'll have to find a new timer in the morning. Thank you!"
