Hi Santhosh, a PE error code is a water level/pressure switch problem. Could be one of three things. First,a bad wire from the control board to the pressure switch. Second,a clogged pressure tube from to tub to the pressure switch could be clogged. Remove tubing from the pressure switch and blow through it to make sure it's clear. Third is the pressure switch itself is bad and needs to be replaced. Hope that helps.
SOURCE: LG Top Load Washing Machine
'de' on LG's stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
