Not sure you can buy pre mixed fuel in Australia? And I've lived there for many years. It is always a good idea to use the manufacturers specific mix..See link..https://www.tyreline.co.nz/2-stroke-fuel-guide/
I know its not your machine, but same idea..cheers
Nah thats 50:1 for bikes just mix it up yerself.
SOURCE: my fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
SOURCE: i have a petrol black
50:1
Farmerbear
Testimonial: "Thanks for the info. I've been trying to get the right mix for ages."
SOURCE: I need to know if the GMC whipper snipper takes
We only have unleaded here in the US, so use that and I recommend using any "synthetic" type of 2-Stroke oil. It is far superior to regular 2-stroke oil and helps your machine live longer.
SOURCE: what is the ratio for oil to petrol for mculloch whipper snippers
hello sir, the gas / oil ratio is, 3/4 o/z per quart or 2.6 o/z per gallon of two cycle oil, any two cycle oil will do,this is how i mix mine and never had a problem,it is a good mix.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ~~
