I unplugged machine for two min replugged and the error is still on and door does not open correct only by pulling the manuel lever and door handel
The User Manual for this model was of no help ... other than to suggest unplugging the unit which you already did ...
I could not find specific error codes for your model ... but F06 on Hotpoint washers in general have two definitions for F06:
F06 - Door lock fault
Issue: Washing Machines door cannot be opened or closed / when the door is closed the machine the programme will not start.
F06 - Program selector dial
Since you are having door issues ... then I would say the door lock is indeed the problem.
Check to make sure there is not any debris in the door lock insert, but my guess is that is not your problem.
It could be the latch on the door or the lock switch mechanism in the machine housing. Odds are it is the locking mechanism
Here is a Hotpoint You Tube on how to replace ... but it is not for your specific model
https://www.youtube.com/watch?v=p14EEa4AYGM
Good luck with your troubleshooting!
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
More than likely the metal spring on the inside of the gas door is broken where the plastic attaches. Have someone hold the fuel door lever in the release position while you gently use a flat head screw drive to open the door. The part should cost you less than $10 at Toyota.
SOURCE: Error 77 is apprearing
Unplug the unit.
Hold down the menu key while plugging back in / powering up.
When finished initializing, hit 99.
Wait to status comes back and hit 91.
This supposedly happens due to a power surge or outage.
If this doesn't work for you try reversing the numbers above.
I have a bad memory, it might be 91 first then 99 but, you definately have to hold down the menu key.
SOURCE: Model Canon MX850. Display error message 6A00.
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Aconteceu com a minha maquina e era o bloca portas.
