Televison & Video Logo
Joseph Posted on Jan 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is a tiny line appearing on my philip plasma tv. please help
rd2xpld
Level 2:
New Friend:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Expert 107 Answers
  • Posted on Jan 09, 2019
rd2xpld
Expert
Level 2:
New Friend:
Teacher:
Answers
107
Questions
Helped
29152
Points
314
Are the lines vertical or horizontal? Are they color or black and white? Right side of screen or left or middle. Intermediate or always there? If you bring up your menu are they in front of the words or behind?
goneforever.
Level 3:
Top Expert:
  • Televison & ... Master 14,531 Answers
goneforever.
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3262989
Points
66315
Bad screen if line is tiny ignore it or buy a new TV if out of warranty then repairing any screen bad is very expensive a tech would re-seat all USB cables inside or try shims in the frame ( a dirty hack free of cost if you did it)
Pablo
Level 1:
New Friend:
  • Contributor 35 Answers
 Pablo
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
21899
Points
63
Try these two easy possible solutions:
Reset the tv by unplugging its power cord for 1 minute and plugging it back in.
Check the coaxial cable for any damage and screw the cable back.
Good luck.
Steve Luck
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Master 819 Answers
Steve Luck
Master
Level 3:
Dedicated:
Answers
819
Questions
0
Helped
218641
Points
2252
If you mean a black vertical line from top to bottom, then it means the TV is on its way out. This has happened to me and I lived withit until it got too wide and I had to replace it with a new one.
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Feb 15, 2008
SOURCE: THICK BLUE LINE VERTICAL LINE ON SCREEN OF MY PLASMA PICTURE
IF THE LINE IS ABOUT 1INCH WIDE THE CHANCES ARE IT WILLBE YOUR PLASMA DISPLY THAT HAS GONE . WOULD BR CHEAPER TO BUY A NEW UNIT . HOWEVER TRY RINGING HITACHI EXPLAIN THE FAULT COMPLAIN THAT IT SHOULD OF LASTED LONGER THAN THE WARANTY AND SEE WHAT THEY WILL DO ABOUT IT
A
Anonymous
  • Posted on Jun 12, 2008
SOURCE: philips plasma tv model#42PF7320A/37
yeah my tv the black bar is getting bigger and bigger
Anonymous
  • Posted on Feb 04, 2009
SOURCE: LG flat panel plasma with red line
I had the same problem and fixed it by replacing the control board. It's a little nerve wracking, but required only simple hand tools. If you'd like to see detailed pictures of the repair check out my blog.
http://greenrenovation.wordpress.com/du-42px12xc-repair/
Anonymous
  • 178 Answers
  • Posted on Sep 03, 2009
SOURCE: Why do i have red lines on my philips plasma tv?
if the lines are going horizontally across and look like someone took a thin magic marker and marked across the screen, you have one of two problems, either some scan ic's have failed or you have a flex cable coming loose from the panel. Either way it will require repair. If it is the flex cable the cost to repair will be beyond the tv's worth because the whole panel needs to be changed to fix this. If it turns out to be the scan ic's, they can be changed or the board the ic's are on may be changed depending on how the repair is approched by the tech. But the cost would be reasonable around 200 to 250.
Good luck
Anonymous
  • Posted on Dec 12, 2009
SOURCE: Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
Here is a photo of the board where I have removed the two from my TV. You can see the two open holes.
I have philips 42' plasma flat tv one white vertical line appear hardly one mm on screen after a month two more line appear in the center of the screen and more two more line appear in screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes are given with illustrations. You can get an idea about the fault to an extent.
Why does my SAMSUNG PLASMA have thin black line? horizontal line How to fix?
Sustain board fault. Contact any service technician. This is not a user repairable fault.
2helpful
How do u fix a philips 50' plasma television with line through it?
The only in-home troubleshooting you can try is unplugging the TV for 30 minutes which will reset it. If that doesn't work the TV will need to be repaired. A line through the picture indicates a failed component inside the TV that needs to be replaced.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
2helpful
2answers
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
2answers
Black Horizontal Lines on Philips Cineos 50" Plasma
First you want to determine if the issue affects the tv's menu if it does you are looking at a Light Engine issue which is expensive if it does not interfere with the On Screen Display the issue is with your signal board, also check to see if this happens on multiple inputs with multiple signal sources if it doesn't you just might want to use a different input which is a way cheaper solution
Panasonic plasma hdtv with crazy red coloring
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Philips 42pf9946/12
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
