SOURCE: dryer and breaker
you have a week breaker or a breaker that is to small you need a 40 amp breaker 20 on each side (two breakers locked into one) or worse you have a short in the dryer. If dryer runs for a little bit and then shuts down its the breaker.if it throws breaker as soon as you plug it in or start it then the short is in your dryer good luck
SOURCE: mde6800ayw - Dryer runs but does not heat.
no it is the heater element needs replacing on the out side of the drum. hope this helps
SOURCE: RE: Roper Electric Dryer, front load
You have a ground fault or short . Disconnect dryer and remove small panel that holds the cord. Check if any wires are frayed, loose or touching any other metal objects.
SOURCE: I have Maytag dryer with Model No. LDG8424AAE. It
how long have you had dryer....have you ever had dryer cleaned out inside...it could be plugged up...chek airflow,disconnect vent line...feel if you have lot of air...or little....then it might be internal tstats problems.....check all this first.....good luck...
SOURCE: Out Maytag Neptune dryer, model # MDE6800AYW, has
Upon starting up the dryer you should hear a clicking noise. That clicking is from the spark ignitor that ignites the burner. If not heard replace the ignitor
