SOURCE: Maytag French Door Refrigerator with ice and water on the door
See the post on Samurai Appliance Repair Man's site http://applianceguru.com/forum1/13035-1.html for instructions on how it's possible to fix the HV Controller Board power supply filter caps for $5 in Radio Shack parts (really!). You need to be able to solder electronic components, or know someone who can. There are 2 power supply filter caps that appear to go bad and the result is the blinking and flapping. I had the same problem and decided I could not wait for a $150 replacement back-ordered board.
SOURCE: the ice maker on our GE refrigerator does not make ice
1 -Ice maker arm must be down(on position)2-Make sure the water supply line is connected to the fridge3Check if the ice maker is plugged in4The freezer must be working fine for the ice maker to produce ice. After the ice maker stars and calls for water and doesn't get any , the water valve is bad.And if everything above is ok the ice maker needs to be replaced.
SOURCE: GE refrigerator ice maker model can9 stopped
The schematic to my CAN9 is cast into the front cover.
SOURCE: Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Testimonial: "Thank you. We will work on that and see what happens. "
SOURCE: LG french door refrigerator ice maker
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
