SOURCE: accessing heat element
You get into the unit from the top. Use a putty knife about 2 inches in from the right and left in the seam on the front of the unit and push in on the spring clip then lift on the top. After that take the front off and work your way down. The heating elements are on the bottom right when facing the front of the unit.
SOURCE: removing front panel on kenmore dryer
I was able to fix my dryer on my own. the problem was, i was instructed to access an area that wasn't correct for the needed repair.
SOURCE: have a kenmore model 110.64962300
Before you begin, UNPLUG DRYER.
Remove bottom access panel by using a putty knife to depress panel clips (item 46).
Check the High limit fuse and heater for continuity. Heater (item 14) <20 ohms and HI-limit (item 47) <0.3 ohms.
If the heater or HI-Limit has failed it may be that the exhaust airflow has become blocked or restricted. Check the hose in the back ofthe machine for crushed hose. If OK, the vent pipe may need cleaning...check out www.linteater.com for vent cleaning info.
If you need further assistance please let me know..
Regards
reg501
The FixYa Team
SOURCE: control panel access
Open the door and remove the top screws connected to the console. Close the door and flip the console down toward you. Remove the control cover to gain access to the control board and the thermal fuse.
SOURCE: Replacing Control Board on Frigidaire model LEQ1442ES0 Dryer
There should be screws on the back side of the top panel that come out. Then the panel will slide out so that you can access the front controls.
