SOURCE: black square in middle of tv
He, he. Somebody activated the subtitle mode on the remote. Desactivate the CC mode on your menu and it'll go away or at least if you want CC put it in CC1 Text1
SOURCE: TV will not turn on.
Most likely your powerboard. Inside those are capacitators that are known to "pop". They have been widely used in many newer tv/monitor units since around '97 I believe. Anyway, Some problems with these things are a little harder to figure out, but a problem that shows a light(flashing/blinking/on for while/off for while) is to my new found knowledge a bad capacitor or 2 in your powerboard. I found a 19" lcd monitor that didnt come on, but the power light is on. I bummed then googled it and found this to be a VERY common problem! I watched a video on youtube how to fix your monitor and openend mine. I found 1 bad capacitator(bad caps show a buldging top and/or fluid leaking from them. one trip to Radioshack and $1.59 The problem was fixed! A rapair man woul;d order your board, install it and charge you around $300 or more. You could change your board yourself(saves money) or you could open your unit and inmspect it yourself first, your fix could be $5 or less!....There are many pic etc to be found on google image for "popped" capacitaotrs(caps), also there are video's on how to replace them on youtube...I hope this helps some!
SOURCE: have a 55 inch hitachi plasma tv. The picture
Seems as if your high voltage power supply went kaput. This happens sometimes see the complaint
at: http://hitachi-home-electronics.pissedconsumer.com/hitachi-55hds69-plasma-tv-20100417178696.html
See: http://www.partstore.com/Model/Hitachi+Ltd/Hitachi/55HDS69.aspx for a list of parts and you can see if it is worth fixing
SOURCE: i have a 47 inch sanyo lcd tv and the screen is
i have a 47" inch lcd sanyo t.v. and my kids accidentally shot it with an air-soft gun. and there is a crack where the pellet hit and there is also a crack running down that spot. Also the screen has these lines running up and down the screen. Different colors. and i was wondering if it was possible to fix.
SOURCE: lower right corner of screen
Hello kailuajacqui:
It sounds like someone has turned on the picture in picture option on your Television. The reason it is a black screen is because it is not setup on a station or other input in order for you to see anything.
Check your manual for how to turn off your PIP (Picture in Picture) option. Or just hit the PIP button on your remote control.
If this helped just click the thumbs up.
Your FixYa team member, Peter N.
Testimonial: "Thanks so much! The problem is solved."
